Lotusscript code for AES Encrytion and Decryption algorithm
Any body is having the Lotusscript code for AES encryption and decryption algorithm.
You can also suggest some other algorithm in lotusscript.
Thanks,
Maheswari.K
Subject: Lotusscript code for AES Encrytion and Decryption algorithm
I did a LotusScript implementation of the Blowfish crypto algorithm somewhere between ten and fifteen years ago, starting from some VB6 code that I found online and modifying it from there. I haven’t looked at that code in a long time (I’m not even sure I could find it if I looked), but think I did this even before the byte data type was supported in LotusScript, so there was likely a fair amount of hacking involved.
I’ve not seen anyone take on AES.
-rich
Subject: Whole lotta ‘nope’
I don’t think it’s possible directly in LS (otherwise you’d see a method).
I found this using our friend Mr. Google.
nsftools - Lotus Notes and Domino Tips (search for AES).
What are you trying to do? Can’t you just use the built in Notes encryption?
Subject: RE: Whole lotta ‘nope’
In our notes application we are receiving a key value in encrypted format (used AES encryption) from some other application written in different technology . We have to decrypt the value received using lotus script. So for that we need AES decryption code written in lotus script.
Maheswari.K
How about using Java to do it instead lf LotusScript? You could take advantage of the Java implementation of AES.
