LotusScript Agent - not running
I have coded a validation agent which is called from a simple button on the webpage. Its purpose is to loop through the existing documents in a view and prompt if there is a document with the same ID. Here is the code :
Sub Initialize
Dim db As NotesDatabase
Dim doc As NotesDocument
Dim viewdoc As NotesDocument
Dim UsedID As String
Dim coll As NotesDocumentCollection
Dim docAction As NotesDocument
Dim view As NotesView
Dim strPath As String
Dim strURL As String
Dim docMatrix As NotesDocument
Set view = db.GetView("luIDs")
Set docMatrix = db.GetDocumentByUNID(doc.ParentDocumentUNID)
Set viewdoc = view.GetFirstDocument
Do Until viewdoc Is Nothing
	If viewdoc.NameID = doc.NameID Then
		'Do Nothing for the Moment
		Exit Sub
	Set viewdoc = view.GetNextDocument(viewdoc)
Loop
Call doc.Save(True, False)
strPath = ReplaceSubstring(db.FilePath, "\", "/")
strURL = "/" + strPath + "/Matrices/" + Trim$(docMatrix.UniversalID) +"?OpenDocument"
Print "[" + strURL + "]"
When i call it all it does is refresh the current page and doesn’t save or load the specified webpage.
Thanks for any help.
F1H
Subject: LotusScript Agent - not running
I would think it would error on the viewdoc.NameID = doc.NameID line …
At any rate, you should pop in some messageboxes and watch the server console while it executes. That’s the easy way to troubleshoot these web agents.
regards,
raphael
Subject: LotusScript Agent - not running developments
Hi.
I have managed to get my agent running and its doing what it should. But my problem is how to load a page after it runs. Do i do it within the agent or back at the QueryWEbSave event? (because what i have in the agent strURL et doesnt work!
Thanks for any help
F1H
How are you calling the agent? documentContext will only work in the way you want if your button has @command([ToolsRunMacro];“myAgent”) to call the agent.
Perhaps the doc doesn’t point to the web document…
Subject: RE: LotusScript Agent - not running
Thanks for your replies. I am running the agent by @command([ToolsRunMacro]). I have found out it is running, bacause the server log has the following error :
01/11/2006 13:20:55 Agent ‘ID Validation’ error: Invalid universal id
Any ideas?
F1H
