Lotus Traveler 8.5.1 and Policy problem
Hi, I love the Traveler product, it works great on my Windows mobile 6 device. I’ve been having a problems with the policy settings though.
I want to set the value for Low Battery Threshold for example. If I use the how to apply setting of ‘Set value and prevent changes’ the policy gets pushed to the phone but it doesn’t if I use ‘Set value whenever modified’.
Also, there does not appear to be any difference in the logging level on my phone if I set the ‘Device Logging Level’ policy setting to either Low, Medium or High. Thanks…
Subject: Same to me
It seems only the prevent changes can be pushed with a different value later.
The other setting seems to work only initially.
Not how policies are supposed to work :frowning:
