Lotus Script "On Error" stops acting after first error
My “On error” routine works fine for the first error, but faced with another, It forgets about the “On error” subroutine, and stops the script.
Very annoying, and an error I haven’t had before.
Any good ideas is very valued.
Kind Regards
Tor-Olav Berntzen
Script as of now:
%REM
Agent ExportAttacedUtstyrdocs
Created Jun 30, 2010 by Tor-Olav Berntzen/SivIngBerntzen/NO
Description: Comments for Agent
%END REM
Option Public
Option Declare
Use “misc”
Use “ymse”
%INCLUDE “lsxbeerr.lss”
Const File_Path = "d:\t\oticUtstyr"
Const ScanDbSrv = “Dom_apps_srv/SivIngBerntzen/NO”
Dim retStr As String
Dim tmpint As Integer
Sub Initialize()
Dim db As NotesDatabase
Dim utstyrview As NotesView
Dim CurrentDoc As NotesDocument
Dim docEntry As NotesViewEntry
Dim notesRTItem, notesRTItem2 As NotesRichTextItem
Dim rtLink As NotesRichTextDocLink
Dim rtnav As NotesRichTextNavigator
Dim errcnt, linkcnt As Integer
Dim currentlog As New NotesLog("Script log")
Dim dirResult, tmpTxt,tmpFileName, fntmp,errtxt As String
Dim item As NotesItem
Dim errorcode, linenum As Integer
Dim linkDoc As NotesDocument
On Error GoTo ErrHandle
Dim linkDb As New NotesDatabase("", "")
dirResult = Dir$ (file_path , 16)
If dirResult = "" Then
	MkDir file_path
Call currentlog.Openfilelog( "d:\t\ScanDocLog_utstyr.log" )
currentlog.LogErrors = True
Set db = session.currentdatabase
Set linkdb = db  '# Dummy assignment
Set utstyrview = db.getview("UtstyrMedLink")
utstyrview.Autoupdate = False
Set currentdoc = utstyrview.getfirstdocument
linenum = 0
Do Until currentdoc Is Nothing
	linenum = linenum +1
	Set notesRTitem =	currentdoc.GetFirstItem("Body")
	If Not (notesRTitem Is Nothing) Then
		'# Remove LinkToSavedFile field
		Set item = currentdoc.Getfirstitem("linkToSavedFile")
		If Not item  Is Nothing Then
			Call item.Remove()
		Set item = New NotesItem(currentdoc, "LinkToSavedFile", Null)
		Print currentdoc.id_nr(0) & " - LineNum " & Str(linenum)
		Set rtNav = notesRTitem.Createnavigator()
		rtnav.FindFirstElement(RTELEM_TYPE_DOCLINK)
		While Not rtnav Is nothing
			Set rtLink = rtNav.GetElement
			If rtlink.DocUNID = String$(32, "0") Then
				GoTo nextdoc
			'	Dim linkDb As New NotesDatabase("", "")
			'rtlink.ServerHint
			If linkdb.Replicaid <> rtlink.Dbreplicaid Then
				Delete linkdb
				set linkDb =  New NotesDatabase("", "")
				Call linkDb.OpenByReplicaID(ScanDbSrv , rtlink.DbReplicaID)
			End if
			'	Print (10/(linenum-linenum))
			Set linkDoc = linkDb.GetDocumentByUNID(rtlink.DocUNID)
			If Not (linkdoc is Nothing) then
				'# Found doc OK!
				'# Check for customer_id directory
				dirResult = Dir$ (file_path & currentdoc.Kunde_NR(0), 16)
					MkDir file_path  & currentdoc.Kunde_NR(0)
				End if
				Set notesRTitem =	linkDoc.GetFirstItem("Body")
				If ( notesRTitem.Type = RICHTEXT ) Then
					ForAll o In notesRTitem.EmbeddedObjects
						If ( o.Type = EMBED_ATTACHMENT ) Then
							tmpFileName = currentdoc.Kunde_NR(0)&"\" & OnlyGoodDosChars(currentdoc.id_nr(0)) & "-" & OnlyGoodDosChars(linkdoc.sertifikatnr(0)) & o.Source
							fntmp = Dir$(file_path & tmpFileName)
							tmptxt = file_path   & tmpFileName
							Call o.ExtractFile( tmptxt )
							item.Appendtotextlist(tmptxt)
							Call Currentdoc.Save(false, false, false)
					End ForAll
				linkcnt = linkcnt+1
			If Not rtnav Is Nothing Then
				Call rtnav.FindNextElement(RTELEM_TYPE_DOCLINK)
		wend
	Delete item
nextdoc:
	Set currentdoc = utstyrview.Getnextdocument(currentdoc)
Loop
MessageBox "Links : " & linkcnt & "Errors : " & errcnt
Call currentlog.Close()
Exit Sub
ErrHandle:
	Call currentLog.Logerror(Err ,Error$ & Str$(linkcnt) & " - " & currentdoc.id_nr(0)& "Line: " &linenum)
	errcnt = errcnt +1
	errorcode = Err
	errtxt = Error$
	MessageBox(Errtxt & " Line: " & Str(linenum))
	GoTo nextdoc
Function removeBadChars(InputStr As String) As String
dim retStr As String
retstr = CrRem(InputStr)
retstr = Trim$ (InputStr)
tmpint = InStr(retStr, "*")
Do  Until tmpint=0
	retstr = Left$(retstr,tmpint -1) & Mid$ (retstr, tmpint +1)
Loop
tmpint = InStr(retStr, "/")
Do  Until tmpint=0
Loop
tmpint = InStr(retStr, "\")
Do  Until tmpint=0
Loop
tmpint = InStr(retStr, Chr(34))
Do  Until tmpint=0
Loop
removeBadChars = retstr
End Function
Subject: try this
There’s one potential cause for trouble in your error handler: You are using GoTo instead of Resume to return after the error is handled.
You may want to try this instead:
ErrHandle:
errcnt = errcnt +1
errorcode = Err
errtxt = Error$
Resume nextdoc
I did not test whether that resolves your issue, but Resume or Exit should always be used to return from an error handler in LotusScript.
Subject: I am so pleased !
It was just the thing…
SOLVED !
