I created one form and one button in that form. Also wrote some code in that button which send some report to different server.
Now i have to write an agent that will take handle of this and code to click that button…
Is their any lotus script code that take handle of button and also code to click that button…Kindly share
Subject: Lotus script code to click hotspot
Show us your code (what you have written) and explain what is not working.
Is the code in the button Lotussript or Formula?
Where will the agent be executing? Client or server? How will it be triggered?
Without more info it is hard to help you, but it sounds like you might be on the wrong track.
I would put the code that you want the button to execute in a function/subroutine. You can put it in a script library for easier sharing.
This function/subroutine is then called once from the button and once in your agent.
Remember, if the agent is running on the server it can only contain/use backend classes, no UI classes.
Subject: Lotus script code to clictton and k hotspot
I think my query is not clear…Let me make it more simple
there is a form “frm” that contains a button “bt”.
There is a view “vw” that contain one document created with this form “frm”
Now i am writing one agent “agt” which picks the created document from view “vw”, take the handle of button “bt” and click that button.
Now my question is
1)Need to write code to take handle of button
2)need code for clicking that button.
here is my code in which i am able to pick the created docuemtn but dont know how to take handle of button “bt”
%REM
Agent testAgent
Created Mar 3, 2016 by Pooja Rani31/India/IBM
Description: Comments for Agent
%END REM
Option Public
Option Declare
Sub Initialize
Dim s As New NotesSession
Dim db As NotesDatabase
Dim col As NotesDocumentCollection
Dim doc As NotesDocument
Set db=s.CurrentDatabase
Set col=db.UnprocessedDocuments
Dim user As String
user = session.CommonUserName
'Print "Collection size: " & col.count
Set doc=col.getfirstdocument
While Not doc Is Nothing
MessageBox doc.day(0)
MessageBox user
'Perform desired operations
Set doc=col.GetNextDocument(doc)
Wend
Subject: Do you really work for IBM?
Will the button just be opening a page, as Karl asked, is this running in a client on the front end?
You still don’t answer two of my three questions:
Is the code in the button Lotusscript or Formula?
Can you show the code on the button? Again, as I said in my first answer, you should put whatever code you have in the button in a function in script library and then simply call that function.
Function myButtonCode()
'*** Code to be executed when button
'*** is clicked goes here
End Function
Then your button code looks like this:
Sub Click(Source As Button)
Call myButtonCode()
And you put a call to myButtonCode() in your agent.
Additionally, do not use extended notation when accessing document fields, use the GetItemValue method instead.
Just a curious question, how long have you been programming using Notes/Domino? The reason I am asking is partially because I am interested to learn if companies still hire new Domino developers.
