Lotus script and javascript for Domino books
Hello! I was wondering if you all would suggest some books that would help teach me java script and lotus script for Domino? I need to learn these languages so that I can start programming with them and I have not found any books that are helpful to the extent of teaching me how to program.
Thanks!
Subject: lotus and java script books
Well, I’m not sure if you meant JavaScript or Java since your subject says one and the body says the other but I’ll offer ideas for both. Here are the best books I have found in regards to both Java and JavaScript:
Java
Author: Deitel & Deitel
Title: Java, How to Program
Edition: (get the latest)
Publisher: Prentice Hall
Javascript
Author: James Jaworski
Title: Mastering JavaScript and JScript
Publisher: Sybex
Hope that helps. You want to pick up a “Java in Domino” book as well since Domino has several classes within itself that aren’t part of the core Java classes.
