Lotus notes to Java connection
Hi All,
I want to connect from notes database to external database which is based on java.
Do i need to install JDK & JRE on my machine ?
If yes which driver I need to configure for the connectivity as in for ODBC connectivity need ODBC driver?
How can I check that data is inserted properly or not as for ODBC or SQL through TOAD can check the query?
Please provide me the code that how to connect with the Java environment…
Thanks for all your guide and support
