Lotus Eeeasysynch Hotsynch problem for PDA
I got a new Thinkpad and I loaded the latest version of Easysynch 4.2.4 to be able to use with my Palm Zire PDA. On my previous computer I used Lotus Easysynch 4.2.1 without problem. Now when I try to sync the PDA I get a message from Easysynch saying that Hotsynch was not detected, even though its running and I can synch to it using just the Palm software. I have uninstalled and reinstalled all the Palm and Easysync software several times, following all the directions for removal and reinstall but Easysync never sees the Hotsynch manager. When I looka the the Hotsynch Manager Custom setup I do not see an Easysynch conduit like I did on my old computer. Any solution to this?
Subject: Lotus Eeeasysynch Hotsynch problem for PDA
Get yourself Commontime’s mNotes
saves you time and money. That’s an application that works, and easysync is just crap.
If you are a IBMer and are trying to install EasySync 4.2.4 from ISSI, then look at the “EasySync Pro 4.2.4 conduit not installed” thread in this forum for solutions.
AJ
