Lost cert password and other problems. Admins please help
I have taken over the management of a client’s Domino 6.5.3 server and have a few problems:
  1. they don’t know the certifier password
  2. the only notes ID they have has expired.
  3. when you try to start the notes client on the server (Win2003 server) you get a message about the client not being able to run while the server is running. There are no icons in the Start menu for Notes or Administrator - just the server.
I’m a Domino developer not an admin so I’m really struggling to work out how to get this happening - I’ve searched the forums but can’t find anything. So, can anyone here help me-
  1. Re-certify the server; and
  2. Get the notes client working on the server.
Thanks in advance,
Michael.
Subject: Lost cert password and other problems. Admins please help.
  1. This is bad. Time to recertify. And investigate the power of documentation.2. See #1.
  2. You shouldn’t be running the client on the server. Use the Admin Client.
I have no idea how many users you have, how they connect to the server(s), or how many apps you have. Recertifying may impact some agents, so it is best to create a lab environment, test recertification, test your agents and apps. And document the procedure.
Then do it on your world. And document your passwords and keep the cert.id safe.
Good luck.
Gregg
  1. Re-certifying the server will not be possible without the Certifier password. If you do not find the password, you will be forced to create a new cert. I just went through this process a couple of months ago when I forgot the password.
If you have to create a new cert, follow Gregg’s suggestion and create a test environment to do all this on. Recreate the notes Id that expired and also create an additonal admin id in case this happens again. Put them in an Admin group. You’ll have to create a new server id since the O Level certs won’t match. On your test server, copy over all the critical applications you need. Since you mentioned only one Notes id, I’m assuming the rest of your users are either CALS (web based) or using some other authentication (LDAP)? Then using your admin client you have to sign all design elements on the applications you copied over. Otherwise you’ll get ECL alerts. If the applications can now be accessed from a client or web browser without any errors then rebuild your production server and copy over the apps, NAB and server id.
  1. You probably need to get to those databases locally to change the ACL right? There is a way to run the client on the Notes server. Look for the nlnotes.exe file. Before running it, delete the bookmarks.nsf file in the data directory. The default bookmarks does not give you access to the Workspace. Now run the nlnotes.exe. Then go into the bookmarks and get to the Workspace. Open your databases and change the ACLs. You won’t be able to sign the design without having Designer or Manager access for your new admin id or server.
HTH
Audie
