Looking for Javascript coding examples after reading Running Custom JavaScript™ – Events in Dleap 1.1.5
Dear Leader Board Dleap 1.1.5,
After reading the principle work of Javacript at Events response:
I am looking to see any related Javascript coding examples how to write it in live Dleap application Event, but fail to find it.
Reach out for getting help/advice to give me a hint; Where to read a few examples to read reference topic about it.
Specifically, using features of Dleap 1.1.5 or the Javascript codes can be implemented in this version.
I am looking forward to hearing from you.
Thank you and Regards,
Frans.
Hi Frans,
It looks like your question is for Domino Leap.
I would suggest you to get started with Sample Apps in our Wiki:
https://hclwiki.atlassian.net/wiki/spaces/HDV/pages/552960012/Sample+Apps
Explore any app as JavaScript in each events is used, and you need to refer to the documentation below about JavaScript events if in case you stuck:
  • Application events
    This topic describes the Application Events, and their parameters when using JavaScript API in Domino Leap.
  • Form events
    This topic describes the Form Events, and their parameters when using JavaScript API in Domino Leap.
  • App page events
    This topic describes the App Page events, and their parameters when using Javascript.
  • Page events
    This topic describes the Page Events, and their parameters when using JavaScript API in Domino Leap.
  • Item and apItem events
    This topic describes the Item Events, and their parameters when using JavaScript API in Domino Leap.
Additionally, if there are other custom JavaScript libraries that you want to understand that used in any sample app, please check this as well for reference:
Using JavaScript in Your Applications
Using JS Libraries in DLeap
Advanced: Using JavaScript Libraries in Domino Leap
Hope this helps.
Thanks,
Jayve
Dear Jayve,
Thank you so much for all the links you have provided, I will read and learn from its content, and will consult with you in the near future, when stuck or have related question(s), hope you do not mind...
Appreciated for care to a new bee like me....hope it also helpful for others beginners, or else...
Regards,
Frans.
Hi Frans, you're welcome. Sure, please post your future questions in our HCL Domino Leap forum as well and will assist you.
Happy to help.
Kind regards,
Jayve
