Load web and load amgr are still not working
03-06-2004 07:46:44 Event Monitor started03-06-2004 07:46:46 Begin scan of databases to be consistency checked
03-06-2004 07:46:46 End scan of databases: 1 found
03-06-2004 07:46:47 The Console file is C:\notes\data\IBM_TECHNICAL_SUPPORT\console.log
03-06-2004 07:46:47 Console Logging is DISABLED
03-06-2004 07:46:47 Unable to run program AMgr.EXE: Unable to locate program
03-06-2004 07:46:47 Unable to run program web.EXE: Unable to locate program
03-06-2004 07:46:48 Database Server started
I did find the following in the logfile:
03-06-2004 07:45:53 Event Monitor started
03-06-2004 07:46:09 Client Execution Security is enabled.
03-06-2004 07:46:18 Agent Manager started
03-06-2004 07:46:20 Event Monitor shutdown
03-06-2004 07:46:23 33:18: Operation stopped at your request
03-06-2004 07:46:23 AMgr: Problem enumerating through the database list to search for agent documents: Program shutdown in progress
03-06-2004 07:46:23 Agent Manager shutdown complete
What is the meaning of this message? and is it related
John Nivard
Subject: Load web and load amgr are still not working
03-06-2004 07:46:47 Unable to run program AMgr.EXE: Unable to locate program>> 03-06-2004 07:46:47 Unable to run program web.EXE: Unable to locate program
Apparently you have created two program documents – one contains the program name “AMgr.EXE”. It should contain simply “Amgr” (or “namgr.exe” if you have a Win server).
The messages below sound like someone told Domino to quit and it is stopping tasks.
Subject: also …
Typically agent manager and the web server run all the time that Domino is up and should be started with the ServerTasks= line in the NOTES.INI rather than a program document.
