Hi, I am having this problem
I have a database that creates a link to a document when certain variables are filled, well for some reason this link only works when the database is bookmarked. I test it and if I delete the bookmarked from the workspace and press the link a message appears telling that document doesn’t exist, if I bookmark the db everything works perfect.
Can I use this function Opendatabase associated with the link ?
Thanks in advance
Here is the code for the link
Sub Click(Source As Button)
Dim session As New notessession
Dim db As notesdatabase
Dim uidoc As NotesUIDocument
Dim L_Doc As NotesDocument
Dim doc As notesdocument
Dim rtitem As NotesRichTextItem
Set db = session.currentdatabase
Set uidoc = workspace.CurrentDocument
Set L_Doc = uidoc.Document
Call L_Doc.Save(True,False)
For i=0 To Ubound(L_Doc.GetItemValue("SendTo"))
Set doc = New notesdocument(db)
Set rtitem = New NotesRichTextItem( doc, "Body" )
Call rtitem.AppendText(L_Doc.GetItemValue("remarks")(0))
Call rtitem.AddNewLine( 1 )
Call rtitem.AppendText("Please follow this link")
Call rtitem.AppendDocLink( L_Doc, db.Title )
doc.form= "memo"
doc.sendto = L_Doc.GetItemValue("SendTo")(i)
doc.subject = "Issue - no. " + uidoc.FieldGetText("no") + " - " + uidoc.FieldGetText("o_headline")
doc.Body= "Please follow this link"
Call doc.send(False)
Next
