Libirc.lib - temporary solution when compiling for x64
Some people get the message that they are missing libirc.lib when compiling for x64 using the c api.
The libarary in question can be downloaded from intel. You will have to download intel’s c++ compiler, and get the library from there.
Happy coding
Thomas Boesgaard
Tags: c-api CAPI x64 64 64-bit
Subject: Intel Compiler is not free
The Intel Compiler is not a free download. This is not an acceptable workaround as our organization will need to purchase a license for the Intel Compiler in order to link with libirc.lib.
This may prevent us from releasing a 64 bit server task.
Please provide another workaround.
