LCStreamFmt for case conversion to Uppercase?
I need to retrieve customer name from a db2 database using LSXLC. I need to convert to upper case to avoid any mismatches due to case.
Subject: LCStreamFmt for case conversion to Uppercase?
Retrieve the string from DB2 using LSXLC. Then use any of the following before comparison is made:
@UpperCase in Formula language.
Ucase in Lotus script.
Or is it that you don’t have provision to write code?
Regards
Byju Joy
