I have a problem with the LCConnection.Select method; It does not return a complete field list when connecting to a notes resource using a form as metadata. Newly added fields dosen’t show…
I should add that the documents based on this form has a lot of fields. Some fields are no longer on the form, only in documents.
Where does the select method obtain the list from? (design og documents)
The field I cannot find is on the form itself, not on a subform.
What could be wrong?
Ove
