Language problem iNotes 8.5.1
what do i have to change in the mailtemplate, that the mailfile in iNotes is allways shown completely in english (not mixed), whatever the browser language is set to?
THX
Subject: Language problem iNotes 8.5.1
It is expected that the mail template strings will be in English unless the mail template has additional language packs added. Are you saying that ALL strings are in English even though another browser language is selected? If so, what browser/version/OS are you using and what is the list of browser accept languages?
Subject: english version
i only thing i want to do is to make a template that shows only english language wether the less the browser language of the browser is.
Subject: RE: Language problem iNotes 8.5.1
We have added a user preference to 8.5.2 that allows a user to select a language that will override the browser language. I believe that will solve your problem.
