JVM Out of memory problem
Hi,all
we have a JDBC agent to pull data from oracle.
but suffer JVM memory leakage problem recently.
From OS memory monitor, it also exhausted.
Is any one have experience about this or suggestion?
Thank you!
PS. I already put many recycle and system.gc code but fail.
05/07/2008 05:02:05 PM AMgr: Agent (‘code’ in ‘ap\xxx.NSF’) error message: <AF[92]: Insufficient space in Javaheap to satisfy allocation request>
05/07/2008 05:02:05 PM AMgr: Agent (‘code’ in ‘ap\xxx.NSF’) error message: <AF[92]: completed in 629 ms>
05/07/2008 05:02:05 PM AMgr: Agent (‘code’ in ‘ap\xxx.NSF’) error message: Exception
05/07/2008 05:02:05 PM AMgr: Agent (‘code’ in ‘ap\xxx.NSF’) error message: in thread
05/07/2008 05:02:05 PM AMgr: Agent (‘code’ in ‘ap\xxx.NSF’) error message: “main”
05/07/2008 05:02:05 PM AMgr: Agent (‘code’ in ‘ap\xxx.NSF’) error message: java.lang.OutOfMemoryError:
05/07/2008 05:02:05 PM AMgr: Agent (‘code’ in ‘ap\xxx.NSF’) error message: at java.io.ByteArrayOutputStream.toByteArray(ByteArrayOutputStream.java:154)
Subject: JVM Out of memory problem
Hi
You can rise the max heap size for the JVM by the setting in Notes.ini:
JavaMaxHeapSize=number of bytes
brgds Jesper Kiaer
http://www.jezzper.com
Subject: RE: JVM Out of memory problem
I add max heap to 256M, it remain longer…But finally, it still run out of memory.
