Javascript problem
Hello
I am facing a problem in my web based application. I have used AJAX in it.
There is one Parent form. On the parent form, there is one combo box, when I change the value in combo box, it would open popup using showmodaldialog function.
Code in combo box…
ProjectMaster(window, document.forms[0].username.value, document.forms[0].proj_category.value);
doLookup_ProjectDetails(this);
ProjectMaster: This function will open popup using showmodaldialog function.
doLookup_ProjectDetails: This function has a AJAX Request to fetch data from view…
When the first function runs it opens popup window which has button “ADD”. On the add button I have given javascript code…
window.close();
window.opener.document.forms[0].combo_box.click();
It comes back to parent window and then runs doLookup_ProjectDetails function in the parent window…
Problem : Sometimes doLookup_ProjectDetails function does not run. But if i put alert before doLookup_ProjectDetails function then it call doLookup_ProjectDetails function.
Please suggest what is the problem…
Subject: Javascript problem
I had a problem a while ago very similar to yours. I was opening a pop up window using showmodaldialog and after closing the window was trying to set text in a div in the parent form and call some functions. I found adding an alert made it work but defeated the object of what I was trying to do.
I never did find out the cause of the problem but the following work around using a timeout worked for me.
JSHeader
function wait() {
setTimeout(‘executeFunctions()’, 1000);
function executeFunctions() {
Add button
window.close();
wait();
