The task:
if I want to save a new dokument in my Notes DB with a date value:21th of moth and a time value 22.00 MEZ until 2.00 MEZ, I will get a message.
The date-value is text and has the notesname: Termin_Start
The time-value is Text and has the notesname: Uhrzeit_Start
My Script(in JS-Header):
function checkdate() {
var tag = document.formular.Termin_Start.value.substr(0,2);
var std = document.formular.Uhrzeit_Start.value.substr(0,2);
var min = document.formular.Uhrzeit_Start.value.substr(3,2);
var flag = “”;
if (tag == ‘21’) {
if (std >= ‘22’) {
if (std == ‘22’ && min < ‘30’) {
flag = “”
} else {
flag = “t”;
if (tag == ‘22’) {
if (std >= ‘00’ && std <= ‘02’) {
flag=“t”;
if (flag != ‘’) {
check = confirm(“Achtung: wegen der Datensicherung des Merkursystems (IRT) soll zu dieser Zeit keine Wartung durchgeführt werden!\nKlicken Sie auf "OK", um diesen Termin trotzdem in die Wartungs-DB einzutragen.”);
return check;
Anyone knows what I did wrong?
Thanks a lot for your help
