Can any body tell me how to validate the following in Java script–
1)@IsMember(“1”;majdim_list)
where majdim_list is a text field
Subject: Java script validation problem
If i would have been in your place i would have created a computed field with formula @if(@IsMember(“1”;majdim_list);“GotIt”;“Sorry”).And would have simply checked the value of the new field using javascript document.forms[0].fieldname.value.If its “Gotit” then its present…or else…
SKS
Try this
var strvals = document.forms[0].majdim_list.value;
var arrvals = strvals.split(“,”);
for (i=0;i<arrvals.length;i++) {
if (arrvals[i] != "1") {
//Your code here
HTH
Sai
