I have major problem with Domino (7) running on AS400 in combination with this. I had a lot of trouble in the past running scheduled agents under Domino 7 that connected to SQLSERVER2000 (using MS JDBC DRIVERS) and never got it to run correctlyI have set the max heap size to 156MB (in notes.ini).
A restart of HTTP corrects the problem of very slow performance for only a while:
2006-11-17 08:39:08 Agent Manager: Agent error: java.lang.OutOfMemoryError: JVMCI156:OutOfMemoryError, IBMJVM_ResizeArray - stAllocArray for new array failed
2006-11-17 08:39:08 Agent Manager: Agent error: at com.ibm.jvm.ExtendedSystem.resizeArray(Native Method)
2006-11-17 08:39:08 Agent Manager: Agent error: at java.io.ByteArrayOutputStream.write(ByteArrayOutputStream.java:112)
2006-11-17 08:39:08 Agent Manager: Agent error: at lotus.domino.ClassHashtable.explodeArchive(Unknown Source)
2006-11-17 08:39:08 Agent Manager: Agent error: at lotus.domino.ClassHashtable.addAttachment(Unknown Source)
2006-11-17 08:39:08 Agent Manager: Agent error: at lotus.domino.AgentLoader.addAttachment(Unknown Source)
2006-11-17 08:39:08 JVM: The addAttachment (Ljava/lang/String;[B)V() method failed.
2006-11-17 08:39:09 Agent Manager: Agent error: Exception
2006-11-17 08:39:09 Agent Manager: Agent error: in thread
2006-11-17 08:39:09 Agent Manager: Agent error: “main”
2006-11-17 08:39:09 Agent Manager: Agent error: java.lang.OutOfMemoryError: JVMCI156:OutOfMemoryError, IBMJVM_ResizeArray - stAllocArray for new array failed
2006-11-17 08:39:09 Agent Manager: Agent error: at com.ibm.jvm.ExtendedSystem.resizeArray(Native Method)
2006-11-17 08:39:09 Agent Manager: Agent error: at java.io.ByteArrayOutputStream.write(ByteArrayOutputStream.java:112)
2006-11-17 08:39:09 Agent Manager: Agent error: at lotus.domino.ClassHashtable.explodeArchive(Unknown Source)
2006-11-17 08:39:09 Agent Manager: Agent error: at lotus.domino.ClassHashtable.addAttachment(Unknown Source)
2006-11-17 08:39:09 Agent Manager: Agent error: at lotus.domino.AgentLoader.addAttachment(Unknown Source)
2006-11-17 08:39:09 JVM: The addAttachment (Ljava/lang/String;[B)V() method failed.
2006-11-17 08:40:05 AMgr: Agent ‘AGetUsersInforFromJdbcOnTimer’ in ‘app/JDBCToMSSQL.nsf’ did not process all documents successfully. Check the Agent Log for more information: JVM: Attempt to retrieve Java agent attachments failed.
2006-11-17 08:40:05 AMgr: Agent ‘AUpdateUsersInforOnTimerJdbc’ in ‘app/JDBCToMSSQL.nsf’ did not process all documents successfully. Check the Agent Log for more information: JVM: Attempt to retrieve Java agent attachments failed.
2006-11-20 08:06:33 AMgr: Agent (‘AUpdateUsersInforOnTimerJdbc’ in ‘app/JDBCToMSSQL.nsf’) error message: Exception
2006-11-20 08:06:33 AMgr: Agent (‘AUpdateUsersInforOnTimerJdbc’ in ‘app/JDBCToMSSQL.nsf’) error message: in thread
2006-11-20 08:06:33 AMgr: Agent (‘AUpdateUsersInforOnTimerJdbc’ in ‘app/JDBCToMSSQL.nsf’) error message: “main”
2006-11-20 08:06:33 AMgr: Agent (‘AUpdateUsersInforOnTimerJdbc’ in ‘app/JDBCToMSSQL.nsf’) error message: java.lang.OutOfMemoryError: JVMXE006:OutOfMemoryError, stAllocArray for executeJava failed
2006-11-20 08:06:33 AMgr: Agent (‘AUpdateUsersInforOnTimerJdbc’ in ‘app/JDBCToMSSQL.nsf’) error message: at java.io.ByteArrayOutputStream.toByteArray(ByteArrayOutputStream.java:154)
2006-11-20 08:06:33 AMgr: Agent (‘AUpdateUsersInforOnTimerJdbc’ in ‘app/JDBCToMSSQL.nsf’) error message: at lotus.domino.ClassHashtable.explodeArchive(Unknown Source)
2006-11-20 08:06:33 AMgr: Agent (‘AUpdateUsersInforOnTimerJdbc’ in ‘app/JDBCToMSSQL.nsf’) error message: at lotus.domino.ClassHashtable.addAttachment(Unknown Source)
2006-11-20 08:06:33 AMgr: Agent (‘AUpdateUsersInforOnTimerJdbc’ in ‘app/JDBCToMSSQL.nsf’) error message: at lotus.domino.AgentLoader.addAttachment(Unknown Source)
2006-11-20 08:06:33 JVM: The addAttachment (Ljava/lang/String;[B)V() method failed.
2006-11-20 08:06:35 AMgr: Agent (‘AGetUsersInforFromJdbcOnTimer’ in ‘app/JDBCToMSSQL.nsf’) error message: Exception
2006-11-20 08:06:35 AMgr: Agent (‘AGetUsersInforFromJdbcOnTimer’ in ‘app/JDBCToMSSQL.nsf’) error message: in thread
2006-11-20 08:06:35 AMgr: Agent (‘AGetUsersInforFromJdbcOnTimer’ in ‘app/JDBCToMSSQL.nsf’) error message: “main”
2006-11-20 08:06:35 AMgr: Agent (‘AGetUsersInforFromJdbcOnTimer’ in ‘app/JDBCToMSSQL.nsf’) error message: java.lang.OutOfMemoryError: JVMCI156:OutOfMemoryError, IBMJVM_ResizeArray - stAllocArray for new array failed
2006-11-20 08:06:35 AMgr: Agent (‘AGetUsersInforFromJdbcOnTimer’ in ‘app/JDBCToMSSQL.nsf’) error message: at com.ibm.jvm.ExtendedSystem.resizeArray(Native Method)
2006-11-20 08:06:35 AMgr: Agent (‘AGetUsersInforFromJdbcOnTimer’ in ‘app/JDBCToMSSQL.nsf’) error message: at java.io.ByteArrayOutputStream.write(ByteArrayOutputStream.java:112)
2006-11-20 08:06:35 AMgr: Agent (‘AGetUsersInforFromJdbcOnTimer’ in ‘app/JDBCToMSSQL.nsf’) error message: at lotus.domino.ClassHashtable.explodeArchive(Unknown Source)
2006-11-20 08:06:35 AMgr: Agent (‘AGetUsersInforFromJdbcOnTimer’ in ‘app/JDBCToMSSQL.nsf’) error message: at lotus.domino.ClassHashtable.addAttachment(Unknown Source)
2006-11-20 08:06:35 AMgr: Agent (‘AGetUsersInforFromJdbcOnTimer’ in ‘app/JDBCToMSSQL.nsf’) error message: at lotus.domino.AgentLoader.addAttachment(Unknown Source)
2006-11-20 08:06:35 JVM: The addAttachment (Ljava/lang/String;[B)V() method failed.
Any help would be greatly appreciated!
