Issue with NotesViewNavigator created from view category that has more than 250 entries
LotusScript code crashes Domino server and client version 8.5 (tested on following platforms: Domino 8.5 @ SuSe Linux, Domino 8.5 64 bit version @ Windows Server 2003 x64, Notes 8.5 @ Window XP, Notes 8.5 @ Mac OS X 10.5.6) when view category has more then 250 entries.
This code works fine on any other Notes/Domino version lower then 8.5 (tested on: Domino 8.0.2 @ Windows Server 2003, Domino 7.0.3 @ Suse Linux and Windows Server 2003, Notes 7.0.3 @ Windows XP)
Actual agent is called from WebQueryOpen event of form, and shows documents for specific date. But I think it’s insignificant, because code in example crashes client too.
Sub Initialize
Dim db As NotesDatabase
Dim view As NotesView
Dim nav As NotesViewNavigator
Dim entry As NotesViewEntry
Dim ssCode As String
Dim ssDate As String
ssDate = "2007.04.11"
Set view = db.GetView("ToDayDocHTML")
Set nav = view.CreateViewNavFromCategory(ssDate)
If Not nav Is Nothing Then
	Set entry = nav.GetFirstDocument
	Do While Not entry Is Nothing
		ssCode = ssCode + entry.COLUMNVALUES(3)
		Set entry = nav.GetNextDocument(entry)
	Loop
Any suggestions?
Subject: Ugh… NotesViewNavigator was definitely updated with 8.5, there’s been a few problems such as this. Have you opened a PMR?
Subject: yep, it’s currently in progress
Subject: Great - please keep us informed.
Subject: its confirmed bug
After upgrading a server to the final release of Domino 8.5 crashes. Aftersome troubleshooting, narrowed down the problem to a specific agent that
had been working fine in all previous versions of the server (various
versions of 7.0.x and 8.0.x);
After further investigation, it was found that the problem was reproducible
on several machines in clean databases and occurred during traversal of a
view using a NotesViewNavigator.
A reproducible crash occurred when running an agent containing only this
code:
Dim session As New NotesSession, db As NotesDatabase
Dim deathView As NotesView
Set deathView = db.GetView(“DeathView”)
Dim nav As NotesViewNavigator, entry As NotesViewEntry
Set nav = deathView.CreateViewNav
Do While Not (entry Is Nothing)
  Set entry = nav.GetNext(entry)
Loop
Subject: Did you receive a PMR# for this you can share with us ?
I having another, somewhat related issue with 8.5.* NotesViewNavigator too, so I wonder if this future Fix will correct my issue too.Thanks
Subject: tested in 8.5.1 CD8 and it works
I copied and pasted your code into a new agent and ran it from Domino Designer 8.5.1 CD8 against a Domino 8.5.1 CD8 server and it worked.
