Is Was FP23 for 8.5.5 supported for COnnections 7
Hi Wannes Rams,
when you check the HCL Connections system requirements page
https://support.hcltechsw.com/csm?id=kb_article&sysparm_article=KB0085090#application
you will see that WAS v8.5.5.23 is currently not listed.
This configuration is marked as "Other Configuration". That means:
Other Configuration - includes many configurations of HCL Products and other software exist that are not explicitly listed as "Supported Configurations" or "Unsupported Configurations", but which can reasonably be expected to perform within the accepted bounds of reliability, function, and performance.
Thanks, Thorsten
From a Support Case HCL confirmed that WAS 8.5.5.23 is supported. Even 8.5.5.24 is supported and available on Flexnet.
Thanks Michael
Hi Wannes,
WAS 8.5.5.23 and 8.5.5.24 can be considered "Other Configurations" for 7.0 since we have not explicitly tested these versions with 7.0. We only designate "Supported Configuration" after testing.
Thank you,
Michael
