I would like to know how much low priority mails are sent during the evening.Is there an existing statistic to help me ?
If not, what could be the best way for me to know it ? Or to make an estimation of it ?
Thanks !
Thanks !
Subject: Is there a way to monitor the number of low priority mails sent ? A statistic ?
Hi Emmanuel
In the Admin help search for ‘statistics’ and also ‘performance’.
Domino has a number of databases and functions that give you plenty of information and do a great job of performance reporting. You can even set up your own triggers and rules to get specific information.
You could check statrep.nsf for example.
Good luck
B
Subject: RE: Is there a way to monitor the number of low priority mails sent ? A statistic ?
Thanks Bizhan, but I’ve already taken a look a the numerous smtp statistics on the statrep db… It seems there is nothing that tells about :- the number of mails in low priority waiting the evening to be delivered ;
In Mail.TransferredSize you can see :
1MB_to_10MB
but it’s not giving the information I need…
Any idea ?
Answer from IBM :
“This statistic does not exist at this time. Currently you can only gather the statistic for ALL mail in the mail.box”
“This has been requested as a feature enchancement in Enhancement Request # JGAN6AQQ44”
