Is there a way of using a combobox to autocomplete if it's populated by a view?
I am trying to find a way of having autocomplete (typeahead, if you prefer) on a combobox or listbox, whatever, it’s
Subject: Is there a way of using a combobox to autocomplete if it’s populated by a view?
You can use XMLHttpRequest to query the database. Julian Robichaux has done the hard work, so no need to re-invent the wheel.
http://www.nsftools.com/tips/ZipLookupTest.htm
cheers !!
Ashish
