I’m new to JSP/Servlets. Is there a guide available some where that will help me start on this?
Your inputs would be highly appreciated.
Regards
Zaheed
Regards
Zaheed
Subject: Try this
Subject: Is there a step-by-step guide to running JSP/Servlets in Domino?
Hi Zaheed,you can’t run JSP in native Domino. This is why your R6 server comes with a limited entitlement to Websphere.
If you rather run Tomcat you will find information on the http://jakarta.apache.org/ pages. If you consider JBoss then http://www.brightline.com/ is a good place to look. In a nutshell:
You configure your JSP server and use redirection and/or a TagLibrary to use Domino resources. Depending on the J2EE server you can enjoy single sign-on.
Hth
stw
Subject: Thanks
Thanks both of you. Much appreciated.
Regards
Zaheed
