Since the update to Sametime 11 some of my clients try to print the conversation of a current chat window launched within the embeded client in Notes.
Here the print option is greyed out. I was wondering why.
Thanks for all tipps
Rainer
Rainer
I think that the printing of the Chat Transcript or Conversation is a Sametime Connect Client feature.
Is the following enabled in the Sametime User Policy:
im.3000.label = Allow all Sametime Connect features to be used with integrated clients (IC)
If not, try doing that.
Policy Settings for reference:
https://help.hcltechsw.com/sametime/9.0.1/admin/admin_policy_im_ids.html
Just keep in mind that if you are using the "Entry" or "Limited" License model, this feature, "im.3000", may not be licensed.
@Rainer Haeberle
Milan is correct, if you have not do not have that setting set there will be some features not availabel
this is documented here: https://support.hcl-software.com/csm?id=kb_article&sysparm_article=KB0078622
and here: https://support.hcl-software.com/csm?id=kb_article&sysparm_article=KB0077735
This has also been fixed in sametime v11FP2.
please see HCL Sametime® 11.0 FP2 Fix List
Please let me know if this was helpful
The reason the "Print" feature is disabled in the embedded client is because it was causing a Notes Client crashes in xulrunner. This issue has been fixed in expeditor which is now being used. If any customer wants to use this functionality they can add the below line in plugin_customization.ini file of Notes Client.
com.ibm.collaboration.realtime.chatwindow/allowPrintTranscript=true
This will enable this feature back and in future versions this property default will be "true".
