Is it possible to get alarms running for more than one databases?
I want to get alarms (followup’s) from my own mailfile and also from another mailfile. As I found out the alarms are depending the mailfile field in the current location document.Is there a possibility to get the alarms of more than one application?
thx i a
K
Subject: Unfortunately, no.
We are considering enhancing this in a future release.
Subject: THX -eom-
