Is Centralized Backup possible when using Hub-Spoke configuration for mail routing?
Is Centralized Backup possible when using Hub-Spoke configuration for mail routing ??
I am planning to cluster the hub servers for high availability.
Thanks in advance
Dinny Peter
Subject: Is Centralized Backup possible when using Hub-Spoke configuration for mail routing ??
I think that I understand your question. I find that when you have a cluster, taking down one of the members and backing that up works well.
HTH.
Gregg
