Hi All,
I have designed a view with editable columns and the property to allow creation of new documents at view level enabled. The Problem I have is that the ability to create new documents at the view level only seems to exist when the view already contains documents. If the view is empty, the “Ctrl-Click here to add a new document” does not appear at all. Am I missing something?
Also, I assume the string “Ctrl-Click here to add a new document” is not configurable?
Thanks in advance,
Niall.
