Integrating Help from Docs 2.0.1 into Connections 7 Help center
I've successfully deployed Docs 2.0.1 with Connections 7. But there is one issue. The procedure described here https://help.hcltechsw.com/docs/v2.0.1/onprem/install_guide/guide/text/additionaldocshelpdisplay.html gives no result. When I try to open help from Docs application it produces 404 error coming from WAS web container. I did some research and found out that the format for help contents seems to differ in Connections 7 and Docs 2.0.1 you cant just update the original Help application as aforementioned procedure suggests.
Any clues on how to integrate help?
Hello Anatoly,
I guess you are talking about the "help" option given in the bottom side of app? if this is the case please have a look on below KB. Hope it would help.
https://support.hcl-software.com/csm?id=kb_article&sysparm_article=KB0086453
Thank you!
Regards,
Pratyush
No, this not the case.
The help in Connections works fine doesn't matter how you launch it. The question is about integrating Help from Docs.
Hello Anatoly,
Just would like to inform that we have a case related to the same issue as you have reported and our DEV team is currently working on this.
Thank you!
Regards,
Pratyush
