We have a problem with installing LN Designer 8.5.1 that was downloaded on Monday. We tried to make the install on:
a) PC with LN 8.0.2 that was uninstalled first
b) PC with LN 8.5 SP1
In both cases the error message: “Error 1606. Could not access network location Description.” appeared at the beginning of InstallShield Wizard (during calculating of necessary space on the disk).
and we are using Czech locale setting. This is the first time when something like that appeared (installing 5.x, 6.x, 7.x, 8.x, 8.5 without any problem).
If you want to install Notes silently the parameter “EnableLangDlg” won’t help.Instead you can edit the section “[Languages]” in setup.ini to enable only English.
Unfortunatelly I have to confirm error 1606 during installation. I have tried to install Designer 8.5.1 on XP SP3 Czech and on Win7 with Czech localization - both with the same unsuccessful result.
Subject: This is a different problem from the initial post …
The install problem with error 1606 means that it is not possible to install LN client at all. The process is breaked at the beginning of install wizard.
Thanks for you reply but I am not sure if we understand. You mentioned to do some changes to notes.ini but there is only notes.ini file of current LN client installed na the PC (8.5 SP1). The install package of 8.5.1 does not have this file.
I tried what you suggested but without success as I expected.
