iNotes problem - unable to find path
I have strange problem and cannot find solution for resolving this.
While adding room to fe. meeting calendar event in Notes Client there is nothing strange. The resource is being booked.
While doing the same in iNotes we are getting “Unable to find path to server. Check that your network connection is working. If you have a working connection, go to Preferences - Notes Ports and click Trace to discover where it breaks down.”
The same message we are getting while synchronizing with IDVault from iNotes.
Any clues, how to resolve that?
I have no idea with what mail server is trying to connect. There is no info on server console. Only “Unable to find path to server. Check that your network connection is working. If you have a working connection, go to Preferences - Notes Ports and click Trace to discover where it breaks down.”.
Are there any Network Debug notes.ini parameters which could help?
Thanks in advance,
Tom
Subject: re iNotes Problem
Can you e-mail me a screenshot of what you are seeing?
Are you on the home mail server hitting iNotes or going through sprayers?
Rahul
gargr@us.ibm.com
Subject: Problem has been solved
The problem has been solved. All looks well after recertification but the Mailserver field in Server Configuration Document has still old name.
After changing the value of that field all problems has gone.
