I have this message on my server console since I moved to 9.0 :
“iNotes Init: Credential Store Configuration not enabled, less secure mode.”
What should I do about it ?
Any help welcome ![]()
Jean-Pierre
Jean-Pierre
Subject: Full message is…
CSRF Init: iNotes_WA_Security_ReturnUrlCheck> c_CSRFReturnUrlCheck: 1
Subject: configure Credential Store database
That message could be more descriptive, but it is indicating that you have not configured the new credential store database, which supports cross server key storage. inotes now uses that for CSRF protection, though you are still protected with a single server, just failover to another server will not be seamless for using the same key.
Subject: Created the Credential Store
Thanks.
I had a look at the documentation and created the Credential Store.
No problem any more.
Jean-Pierre
