Inotes and Treo 600 smart phone from PalmOne
Is it possible to view the iNotes calendar from the Treo Palm One phone. The calendar will not display as it says it is too large.Is there a work around?
Thanks for your time.
JA
Subject: inotes and Treo 600 smart phone from PalmOne
  • My wife, who has a Treo 600, says you can go to Options → Preferences in Blazer, then click the Advanced button. First, click the Memory Management button and be sure the cache is cleared. If it still won’t load, the screen where the Memory Management button is shows your maximum cache size, and how much free memory you have available to use as cache. You can adjust the maximum cache value to bump it up.- If this doesn’t work, she’s fresh out of ideas. Hers is currently set to 1.6MB, and she says she almost never gets a “too large” message, but then she doesn’t load CNN. (grin) Can’t, actually. Blazer can’t handle it.
  • I have a Sharp Zaurus SL5500, and its Opera 6 browser uses all available memory for cache by default. I typically have about 7MB free, and I have yet to find a single page that won’t load with it, even Notes mail, though it takes a really long time to load, even over WiFi. I couldn’t see doing it at Treo 600 speed over the cell network, myself.
  • Also, the multiple frames make mail hard to read on the superior Zaurus screen. I don’t see how a Treo 600’s screen could manage. Naturally your mileage may vary … I’m merely providing information that you may or may not find usable. I haven’t tried loading the Calendar, either, so I don’t actually know about that.
  • Hope this helps…
