Hello All,
Here is a code snippet through which you can create an animation of 3D rotation on Y-Axis in an Iris project.
Output:
Code Snippet:
* @function animateProgressIndicator
* @scope private
* @description 3D translation animation
* @param widget {reference of widget to be animated}
* @param duration {decimal Value}
* @param iterationCount {Integer}
animateProgressIndicator: function (widget, duration, iterationCount) {
voltmx.print("#### Entering into animateProgressIndicator ####");
var transform1 = voltmx.ui.makeAffineTransform();
transform1.rotate3D(0,0,1,0);
var transform2 = voltmx.ui.makeAffineTransform();
transform2.rotate3D(90,0,1,0);
var transform3 = voltmx.ui.makeAffineTransform();
transform3.rotate3D(180,0,1,0);
var transform4 = voltmx.ui.makeAffineTransform();
transform4.rotate3D(270,0,1,0);
var transform5 = voltmx.ui.makeAffineTransform();
transform5.rotate3D(360,0,1,0);
var animationObject = {
0: {"transform": transform1,"opacity":1,"stepConfig":{"timingFunction":voltmx.anim.LINEAR}},
25: {"transform": transform2,"opacity":1,"stepConfig":{"timingFunction":voltmx.anim.LINEAR}},
50: {"transform": transform3,"opacity":1,"stepConfig":{"timingFunction":voltmx.anim.LINEAR}},
75: {"transform": transform4,"opacity":1,"stepConfig":{"timingFunction":voltmx.anim.LINEAR}},
100: {"transform": transform5,"opacity":1,"stepConfig":{"timingFunction":voltmx.anim.LINEAR}}
var animationConfigObject = {
"duration":duration,
"iterationCount":iterationCount,
"direction":voltmx.anim.DIRECTION_NONE,
"fillMode":voltmx.anim.FILL_MODE_NONE
var animationCallbackObject = {"animationEnd" : function(){}};
widget.animate(voltmx.ui.createAnimation(animationObject),animationConfigObject,animationCallbackObject);
voltmx.print("#### Exiting out of animateProgressIndicator ####");
Thanks and Regards,
Venkata Raju Bankapalli
