Important Information for Volt MX Go Customers when Upgrading to Volt Foundry and Volt Iris v10
Volt MX Go v10 is planned to be available in September 2025 in conjunction with an updated version of Volt Foundry and Volt Iris and will enable Volt MX Go capabilities on top of the latest release of Volt MX. Volt MX Go customers who wish to upgrade Volt Foundry or Volt Iris to v10 before then should be aware of the following:
Volt Foundry v10: Volt MX Go v2.1.2 can be installed on Volt Foundry v10.0.0.0. If you wish to upgrade to Volt Foundry v10, you may do so and run the Volt MX Go v2.1.2 installer to install the relevant Volt MX Go plugins and adapters on Volt Foundry.
Volt Iris v10: Volt MX Go v2.1.2 cannot be installed on Volt Iris v10.0.0.0. Volt MX Go customers should not upgrade Iris to v10 and should continue using Volt Iris v9.5.52+ until Volt MX Go v10 is available.
