Goal: Application, requires an email response to be sent to customer. User will press button, creating a new uidoc with the information the customer needs. User is prompted with Contact Name and Email Address and asked if email should be sent.
Problem: No errors, nothing in log, no dead mail in mail.box on any of the servers. Email is not delivered to external address.
Document has the following fields:
SendTo (defined)
MailOptions = 1
SaveOptions = 0
Subject (defined)
Code:
Dim euidoc As NotesUIDocument
Dim answer As Integer
Set euidoc = w.ComposeDocument( "", "", "responseToCustomerEmail" )
answer% = Messagebox("Response being emailed to... " + Chr(10) +_
"Contact = " + curdoc.custContactName(0) + Chr(10) +_
"Email Address = " + curdoc.QAresponseReference(0), 36, "Send Email?")
If answer% = 6 Then '6 = yes
Call euidoc.Send
Call euidoc.Close
Else
Call euidoc.close
I have spent hours in trial and error - searching and trying… any help would be greatly appreciated.
Mike
mferrari@accuride.com
Subject: I searched and searched - now turn to you all… need help with NotesUIDocument.Send
Where is SendTo “defined”?
Subject: RE: I searched and searched - now turn to you all… need help with NotesUIDocument.Send
Two ways… first I have it as a computed field inheriting the values off the curdoc - then reading posts (actually I think one of yours filesave, I added in a line of code that said uidoc.fieldsettext(“sendto”,curdoc.QAresponseReference(0))
m
Run the code with the debugger on to make sure SendTo has a value…
unfortunately I can’t do that…as the set euidoc = w.ComposeDocument won’t work in the debugger.
however,
AFTER my euidoc.FieldSetText
BEFORE my euidoc.send
I added
Messagebox(euidoc.FieldGetText(“SendTo”))
and this gives me the correct external email address.
Try saving instead of sending your test document. I suspect you’ll find that SendTo has a value of blank.
I’d suggest using a dialogbox for this. Include on the form you display in the dialogbox any fields you need (e.g., SendTo, Body). If user clicks OK, send the message.
Since I have the sendto populated - it shouldn’t be blank (but I will try) and the only problem with the dialogbox is that gives the ability for the user to change the destination - perhaps this is workable - just wasn’t intending to give this option.
Subject: You can use a computed field
You can use a computed SendTo field in the form you open in the dialogbox. Then the user won’t be able to edit it.
