I need to removesome info from a multivalue field
From the client document I am trying to remove the
from the computed field that came form the web… here is the value of the field,
“a) The cleaning staff
b) The members of the court
c) The DG
d) None of the above”
when being display on the document it should be;
c) The DG
I have tryied… @implode and @explode… but no luck…
thanks
Paul,
Subject: I need to removesome info from a multivalue field.
If its a single value field then try@ReplaceSubString(FieldName;“
else for multivalue you can try
@Replace(FieldName;“
cheers!!
Ashish
