Hi,I would like a very simple welcome page, similar to the default one when you first logon to notes. But instead of the buttons Mail, Calendar, Contacts, To Do List and Personal Journal I just want buttons that link to databases of my choice. No views or frames or any fancy stuff, just two or three buttons that link to my notes databases.
Can this be done?
Thanks in advance.
Subject: I Need Help To Create a Very Simple Welcome Page
Click on “Welcome Page Options” and follow the instructions.
Subject: RE: I Need Help To Create a Very Simple Welcome Page
The Welcome Page Options are good for designing a welcome page with frames and views and the like but unfortuately it can not give you the very simple welcome page that I want (just a page with two or three buttons with links to my databases). It looks like I’ll have to modify the design a form with Designer as Klaus said.
I made a Clean Sheet document in my Journal. Then I looked in its properties and copied its notes URL to the clipboard. I used the Welcome Page wizard to create a page with one frame containing a web page, and pasted the URL. The result is a little odd-looking, but I can copy and paste bookmarks there to link to databases. This method does not require Designer.
Yes. But u will have to edit the design of your bookmarks database. Probably the form named WPDefaultBasics.
