I have a problem with a TextArea2 field
Please, I have a form with a field of type TextArea2, when displaying the content in desktop web browsers the bar appears, on Android or iOS it does not appear. I need it to appear. Can anyone help?
Hi Marcelo
Thanks for posting the question in the forum. Kindly suggest bar implies the scroll bar with in the TextArea2 widget?
Can you please provide us the screen shot for our reference.
Segue a captura. Neste exemplo o conteúdo real é maior do que é exibido, eu espera que fosse habilitada a barra de rolagem, mas isso não acontece.
Hi Rubens Marcelo
Thanks for providing us the screen shot.
As of now scroll bar option for Android in TextArea2 widget is not yet available. For desktop web applications you can enable this option using custom CSS but this facility is not available for Android and iOS
We already have an idea request for the same where you can add your comments to the same to add more weight to the idea request.
https://volt-mx.hcltechsw.com/ideas/IRIS-I-305
