I got problem with loop in Ls
Hi guys, I am creating a button, by which it detect a number of selected document in view, and then compose a new document on each of the selected document.
The problem is, when I select 3 documents in the view and run the code, instead of generating one new document on each selected document, it generate 3 same document on the first selected document. Below is the code, hope you guys can help me out… I suspect the problem is with the GetNextDocument.
Dim collection As NotesDocumentCollection
Dim doc As  NotesDocument
Dim db As NotesDatabase
Dim Uidoc As NotesUIDocument
Set db= session.CurrentDatabase
Set collection = db.UnprocessedDocuments
Set doc = collection.GetFirstDocument
While Not(doc Is Nothing)
	Set Uidoc =  workspace.ComposeDocument( "", "", "InvoiceForm" )
	Call Uidoc.Save
	Call Uidoc.Close
	Set doc = collection.GetNextDocument(doc)
Wend
Subject: don’t use composedocument
If you’re using back end classes, and you don’t need the user to see the new document (which you don’t by the looks of things as you close it stragith away), just create the new document in the back end as well
dim newdoc as notesdocument
set newdoc = db.createdocument
newdoc.form = “InvoiceForm”
call newdoc.computewithform(false, false)
call newdoc.save(true, true)
Wend
This will just compute the default values for the new document, if you’re using composedocument for inheritance you will have to do that work manually (get the values of doc and write to the correct fields in newdoc)
Subject: thx for the solution
Thanks for the proposed solution Sir. Besides, I had discovered a different approach. It has combination of both LS and formula language.
For the button
@Command([ToolsRunMacro];“Scount”);
@Command([ToolsRunMacro];“Composer”);
@Command([FileCloseWindow]);
Below is the code for agents
Scount (Agent with target as selected doc)
Sub Initialize
Dim s As New NotesSession
Dim coll As NotesDocumentCollection
Dim count As Integer
Dim w As New NotesUIWorkspace
Dim uidoc As NotesUIDocument
Set db = s.CurrentDatabase
Set coll = db.UnprocessedDocuments
Set uidoc = w.EditDocument
Call uidoc.FieldSetText("count",Cstr(coll.count))
Call uidoc.Save
Call uidoc.Close
Composer (Agent with target as None)
@For(n :=1; n<=@ToNumber(@GetField(“count”)) ; n:=n+1 ;
@Command([Compose]; “InvoiceForm”);
@Command([FileSave]);
@Command([NavNextSelected])
I know this method is long, but I personally more prefer formula language. Hence I use LS to count the number of selected doc, and setfield into a hiddenfield.
Formula will do all the rest, it will getfield from the hidden field, and set the number of loop should run.
