I beg for a solution!
Hi, i am facing a problem… pls help me with a solution… am more than appreciate thank you…
i have a richtext field, and that field is mandatory… when attachment is put in the field… it cannot be submit… cos only when text is entered in the field then can submit… i check the field by doing this…
If uidoc.FieldGetText(“attachment”) = “” Then
Msgbox “Please add your attachment”, 64, “Error”
Call uidoc.GotoField(“attachment”)
checkFields = 1
Exit Function
this ‘attachment’ field is a rich test field…
pls help me with a solution… thank you very much :slight_smile:
Subject: i beg for a solution!!!
So you want it that only text can be entered, and no attachments? Why not use a richtext lite?
Martin Vereecken
http://www.bizzybee.be
Subject: Validate Richtext Function
Function validatert(doc ,uidoc,bodystr) As Boolean Dim hasInfo As String
Dim i As Integer
Dim rtnav As NotesRichTextNavigator
Dim elemType(1 To 8) As Long
Dim tempDoc As NotesDocument
Call uidoc.refresh(True)
Set doc = uidoc.document
Set body = doc.GetFirstItem(bodystr)
If body Is Nothing Then
	validatert = False
	Exit Function
Set rtnav = body.CreateNavigator
Dim rtrange As NotesRichTextRange
Set rtrange = body.CreateRange
elemType(1) = RTELEM_TYPE_DOCLINK
elemType(2) = RTELEM_TYPE_FILEATTACHMENT
elemType(3) = RTELEM_TYPE_OLE
elemType(4) = RTELEM_TYPE_SECTION
elemType(5) = RTELEM_TYPE_TABLE
elemType(6) = RTELEM_TYPE_TABLECELL
elemType(7) = RTELEM_TYPE_TEXTPARAGRAPH
elemType(8) = RTELEM_TYPE_TEXTRUN
For i = 1 To 8 Step 1
	If rtnav.FindFirstElement(elemType(i)) Then
		hasinfo = "Yes"
		Exit For
	Else
		hasinfo = "No"
Next
If hasinfo = "No" Then
	validatert = False
	Exit Function
Else
	validatert = True
End Function
