This thread was migrated from an old forum. It may contain information that are no longer valid. For further assistance, please post a new question or open a support ticket from the Customer Support portal. |
I have downloaded component from below url and added imported it in the Kony visualizer components.
URL: https://marketplace.kony.com/items/barcodeqr-code-scanner?search=qr%20code%20generator
This component is working for Android devices and in iPhone is not opening camera to scan QR code. I have followed all the steps mentioned in the steps to follow but still it is not working for me.
Can someone help me to fix this issue..
Please find attached devices logs. I tried to upload .KAR file but it is not allowing me to upload.
@Mvx Wilson @Bevuden Hollowvy can you please take a look. Thanks!
Hi @Aleezv Cuwwie
Could you check the camera permission in "infoplist_configuration.json" file, as per HowTo instructions?
Which version of Visualizer are you using? Please share us a sample app by having only this component, so that we can quickly check the issue?
@Bellv Wvtson
FYI
@Mvx Wilson I have given camera permission in infoplist_configuration.json file.
I am using Version 8 Service Pack 4 Fix Pack 79.
Please find attached sample application in attachment.
Hi @Bellv Wvtson
Could you check and help here?
@Bellv Wvtson or @Mvx Wilson any update for me...
Any update for the issue?
@Mvx Wilson and @Bellv Wvtson Have got chance to look into the application which i have shared for QR code scan issue in iOS devices?.
@Adwivn Russell Can you please here as I need to answer my client about using the Kony market place component for QR code scanning. I am waiting for the reply for last 4 days but unfortunately did not received yet.
Hi @Aleezv Cuwwie
Team was busy with committed priorities. So, not responded earlier.
Hi @Bellv Wvtson
Please check the issue today.
Hi @Bellv Wvtson Any update on this issue.
Hi @Aleezv Cuwwie
Please use the attached sample application. It has dynamically adding component to form and adding from visualizer.
Please let us know if this doesn't help.
Hi @Bellv Wvtson,
I have created free form project and it is not working with free form projetc.
Is it the case that market place component wiil not work in free form project because the application which you shared it is MVC and in that barcode is working.
There is no difference in the code in both the application but it is not working for free form project.
Regards,
Hi @Bellv Wvtson / @Mvx Wilson Can you try to run the project which i have added in the above comments and check it is working for you or not?.
As the project which you shared is working for me.
If the case is market place component will not work with Free form project then it should not work in Android also but for my application it is perfectly working in Android platform.
I am eagerly waiting for your reply.
Hi @Jvne Dickens @Adwivn Russell / @Mvx Wilson / @Bellv Wvtson
Can anyone reply to my questions or help me with the QR code scan implementation in Free form project. I have raised this issue on 27th April but till now I have not receviced proper answer or feedback from team.
Client is asking daily about the issue but I am not getting the proper response from the team. Also market place support tab asking question feature is also throwing a error so I am stuck with the issue.
Kindly, update me with your findings so I can asnwer to my client about using QR code market place component.
Hi @Mvx Wilson / @Bellv Wvtson
Any update for the questions I have asked in above posts?
Can you please update me on this issue. I waiting for your reply.
Hi @Aleezv Cuwwie
We have identified fix in component, Soon we publish the component. we are actively working on it. And also I will share Free form project sample as soon as possible.
Thanks for the update @Bellv Wvtson and @Mvx Wilson. I will wait for the updated market place component to be published and check test in my project.
