Hi All,
I have a problem with http task, we have 3 servers in cluster, and one IP-Sprayer in front making a balance and failover.
The problem is that at some moment the users not recieving responses from the server, the http task respont (see in telnet server 80 and 443) but the users not reciveing more data from the server, and the only one making remains is restart the server.
We verifing that this problem occur after 26 or 30 hours after last restart.
These servers working in cluster and providing a critical web application.
Somebody has some a similar problem ?
Regards
MpM
Subject: Http Problem
There are some definite problems in HTTP that cause the server to quit responding after awhile. It could be number of distinct users, a general memory leak, or anything really.
I would recommend upgrading to the most recent version you can, and definitely check out 6.5.4 when it comes out. From 6.5.2 to 6.5.4 there are 50+ fixes specifically for the web server.
Subject: RE: Http Problem
Hi Eric,
We have in México servers with 6.5.2 with W2003, and we have a same problem…
I see anouncement in fix list for 6.5.4, but this fix it will be available in ~120 days…
You have a same problem ?
Another information, my all servers use SSL…
Do you have another suggest ?
MpM
We have a 6.5.2FP1 server that occasionally gets extremely slow to respond for some (but not all) users, every 7-14 days. Completely restarting HTTP via “tell http quit” and “load http” usually fixes the problem. A separate (though possibly related) problem causes HTTP to completely hang along with the console, forcing a restart of Domino.
You may be able to set up a scheduled nightly task that restarts the HTTP task. That’s not the best solution, but a scheduled non-peak restart may be better than an unscheduled crash during peak usage.
Upgrading to 6.5.3FP1 may help, though I doubt it will help much, and there are a few regressions in 6.5.3 that you may need to watch for. Check the Fix List database first.
You could also open a ticket with Lotus Support. They may be able to supply you with a patch that has some of the 6.5.4 web server fixes.
Hi Eric,
Yes, in a last sunday we initializing tests with one task schedule in one server, and this server that restarted successfull and don’t have problems so far…
Based in history, tomorrow we will have problems…
I am favorable in migration to 6.5.3, but we will depend for homologation of the development team in our test environment.
We have a ticket openned with IBM, but we not have answer…
In your case the http task respond but your clients do not reciveing data from server too ?
Regards.
MpM
The behavior varies:
Case #1: The HTTP task responds to console commands, but some (not all) users hitting the server take over 2 minutes to receive data. CPU use is low, and the number of threads in use and users logged in is also very low. “tell http quit” then “tell http load” sometimes helps the problem. Sometimes a full server exit is needed.
Case #2: The HTTP task quits responding completely, including console commands. A full server exit is needed.
Some of this behavior could be caused by problems fixed with SPRs in 6.5.4 that are listed under “Server” and “Web Server”. Hopefully some of the problems will be fixed in that release.
I’m curious - are you using the ini setting “notesusehttpmemory=0”?
Hi Eric,
We have the two cases…
I also wait anxiously for 6.5.4…
No, we don’t use this setting “notesusehttpmemory=0” in notes.ini…
What make this setting ?
Regards,
If you search for the setting here you will find information about it. If your HTTP task reports “out of memory” problems this setting allows the OS to manage its memory instead of using the standard Notes memory management. Our server is using it, though the problem occured both before and after we started using the setting.
Good Morning Eric,
I search in Ask Professor INI, Notes.net and Google about this setting bus unsuccess…
In this week i making tests with restart server in schedule task, and my servers stop some problems
it’s very good…
I think that this problems occurs by memory leak… what you think ?
Regards.
MpM
A memory leak could be the problem. Unfortunately the server doesn’t actually crash so there is no debugging information available. Hopefully 6.5.4 will help!
Yes… i think thak 6.5.4 resolve this too…
Ok… Friend, nice to meet you and see you in the forum…
King Regards,
MpM
My pleasure! Hopefully we will talk again and celebrate 6.5.4.
Hi Eric, one more question…
How many maximun on-line users you have per server in your environment ?
regards,
MpM
Subject: Re: Http Problem
We may have 20,000 or so that log in over a few days, but usually no more 300 at any one time. We’re using session-based authentication with a 90 minute timeout.
Subject: Marcelo: Re: Http Problem
Hi Marcelo - just giving you an update if you’re still reading this thread.
We upgraded a heavily-used production server to 6.5.4 nearly one week ago, and it has been rock solid - no crashes, HTTP hangs, or reports of “hung threads”.
I haven’t tried to shut it down yet to see if the problem “Waiting for worker thread…” is gone, but overall it is much more reliable than any other 6.5.x release.
Before the upgrade the server needed to be restarted at least every 48 hours (6.5.2FP1).
