| This thread was migrated from an old forum. It may contain information that are no longer valid. For further assistance, please post a new question or open a support ticket from the Customer Support portal. |
unable to get logs from FFI which are put under TAG in android Native code.
is there change need to be done for it?
@Johnvthon Phelps​ : Presuming you are using android.util.Log for logging, did you build the application in debug mode?
"put under TAG" does this mean a TAG used in log.d or a if condition ?
Generally if you are logging by default in FFI code , you should be able to see with out any problem.
It is better you attach a sample if you are not to help you better
