I would like to verify on what servers the Catalog task is running. Normal it is set in the ServerTasksAt1 but can as well be set in a program document.
Can I somehow pull this information (in notes.ini) from all servers - guess I need an agent for this or?
Or can I update the ServerTasksAt1 line in the notes.ini without removing other entries in the line?
Thanks.
Kjeld
Subject: How to verify if catalog is running
You can verify it from server task in Admin client also, name of task is Dirctory Cataloger path is Server-> Status-> Tasks and its normally setup in Servertasks= Replica,Calconn, router, DirCat…etc in Notes.ini
I suggest you should put repeat interval of 15 Min from Configuration-> Directory->Setting option because this task doesnt utilize too much memeory
Thanks,
Disen Joshi
Subject: RE: How to verify if catalog is running
thanks for your reply. Problem is that I have to browsw thought XX servers. Am too lazy for that and would like to get the info in one go…
Kjeld
