How to update the environment, resolve problem calendar entries, and avoid future problems regarding the Brazil DST 2019
In 2019, Brazil is no longer following Daylight Saving (DST). DST will not start on the first Sunday of November. It is not certain if this change will continue in the future. How to we avoid issues with Notes/Domino products?
Check out the following Knowledge Article for more information:
Brazil no longer following daylight savings time (DST) on 2019
This is a live document and will be updated as additional information and fixes are available.
iNotes DST fix for Domino 9.0.1 FP10 and Domino 10.0.1 FP3 is now available for download in the DST knowdege article:
Verse On-Premises:
A fix for HCL Verse On-Premises 1.0.8 is now available for download: HCL Verse On-Premises 1.0.8.A Release Notice and Fix List
Two updates:
SmartCloud Notes Web and Verse:
A fix for SmartCloud Notes Web and Verse has been applied in the service.
Sametime Connect client:
Steps to update the JVM used by the Sametime Connect client: Sametime Connect client not following the 2019 daylight savings time (DST) settings for Brazil
A supplemental calendar agent is now available for use if new or existing calendar entries appear off by one hour for part of January and February of 2020.
Brazil DST - 2019/2020 - supplemental agent
