How to set max number of lines for label in SPA?
This thread was migrated from an old forum. It may contain information that are no longer valid. For further assistance, please post a new question or open a support ticket from the Customer Support portal.
I have set max number of lines for label in android/iOS it was working with below property
lbl1.maxNumberOfLines = 4;
How to set max number of lines for SPA?
Below is the screenshot for platform availability as per document.
Based on the screenshot shared by you, it clearly shows that The property which you are expecting is not Available for SPA.
This is only available for Windows Mobile, Android, iOS.
As of now this Property is not yet available for SPA.
If you wish i will create an idea on behalf of you regarding this property.
Then our product team will review the idea and Provide a fix if this a valid feature request.
Thank you,
Thanks for your reply.
is there any other general possible way to show in SPA?
Thank you,
Hi @Lillivn Dickens​ , Maybe you can try using some Custom CSS properties[http://jsfiddle.net/csYjC/1131/] on that label.
