How to send POST over TLS 1.2 with Lotusscript
I am sending XMLs over POST via the MSXML2.XMLHTTP object:
' Create objects to DOMDocument and XMLHTTP
    Set objDom = CreateObject("MSXML2.DOMDocument")
    Set objXmlHttp = CreateObject("MSXML2.XMLHTTP")
' Load XML
objDom.async = False
objDom.LoadXml XmlBody
' Open the webservice
objXmlHttp.open "POST", Url, False
' Create headings
objXmlHttp.setRequestHeader "Content-Type", "text/xml; charset=utf-8"
objXmlHttp.setRequestHeader "Content-Length", Len(XmlBody)
' Send XML command
objXmlHttp.send objDom.xml</code></pre>
I understood that MSXML2.XMLHTTP is sending over TLS 1.0. The system where I am sending my data to will be disabling 1.0 and 1.1 and will only use 1.2. Is there a way to also send data over TLS 1.2 with Lotusscript and IF possible via MSXML2.XMLHTTP?
My server is using Domino 9, FP10.
SOLUTION:
Changed:
to
Set objXmlHttp = CreateObject("WinHttp.WinHttpRequest.5.1")
'force TLS 1.2
objXmlHttp.Option(9) = 2048
objXmlHttp.Option(6) = True
This worked. Checked with Wireshark, post is going over TLS1.2.
Also used:
I don't know about the MSXML2.XMLHTTP object (isn't it using parts of an installed Internet Explorer?).
With LS2J should should be able to use Java 1.8 to make this POST request.
Or perhaps you could use a Java agent instead of LotusScript?
SOLUTION:
Changed:
to
'force TLS 1.2
Also used:
